blue smoke ?
blue smoke ?
hi all, just a quick question really as ive been told this could be numerous things, when i start the car, it chugs to life and sounds rough as nails till it gets warm, when it reaches around 70degrees, it starts chugging again but puffing blue smoke out, could this be the valve stem oil seals or something ? it will do this for about 2/3 minutes till it clears itself and im just starting to wander what it could be, im running it on veg and diesel if this has anything to do with it, thanks...
with running veg uinsure on your location but if its cold starting the veg wont help,use a higher ratio of diesel
blue is oil - maybe get some oil cleaner/additive
[Image: sig.jpg]
will do mate, could i put an additive in with veg or does it have to be just diesel ? thanks
Could be valve stems if bit clears up but mine done this running on veg. Change your fuel filter
just had a new fuel filter 200miles ago, does this narrow it down then ? lol
Blue usually means oil and could come from a variety of places. Turbo oil seals? Do you need to top up the oil?
I would avoid aditives with veg, it can do funny stuff like make fats drop out. This time of year I blend with 25% misfuel which I collect for free from places that run recovery trucks.
I'd still check the fuel filter. They can last a while or only a few hundred miles. Either way mine was starvation. Issues
i will do, thanks for your help
Sad Blue Smoke KilianManning 10 7,326 28-09-2015, 11:44 AM
Last Post: KilianManning
  Any descent mechanics blue smoke? blinkyeatu 22 11,441 31-08-2015, 06:44 PM
Last Post: blinkyeatu
  Light blue smoke Nathan1305 5 3,666 26-02-2015, 01:36 PM
Last Post: Seb_Ryan
