	Threads: 127
33
Car Model/Spec: ZX Volcane TD
		How do you get your bits shiny shiny?
Tried cleaning up my pump case a bit, used some gunk which did naff all even after a few applications and some vigorous stiff brush work.
Not after a polished look on the case, but the clean sandblasted look would be nice.
	Threads: 22
6
Car Model/Spec: 306 HDi Stage 1
		try wonderwheels.....it shifts 99% of everything
	Threads: 127
33
		Lol, alloy wheel cleaner didn't really touch it
Left it in diesel for a couple of days which helped a bit, but not much.
Gave up and put it back together, at least there is a hint of silver coming through now
	Threads: 130
82
Car Model/Spec: 106 GO-NAD
		agreed with jonny, carb cleaner, brake cleaner, petrol, paraffin, anything like that. if it smells like it'll make your head float away from your body, chances are it'll clean it
	Threads: 3
Car Model/Spec: Need ZX dervv :-(
		If you have it stripped and as long as its a WELL ventilated area ive always cleaned external bits with caustic soda! Dont leave it in there long as it will quickly eat through the alloy.... Can really see the shit melting off hahah.
P.S. Caustic soda eats Alloy... dont get it on any surfaces that are machined or the likes, thermostat housings/gearbox cases/ inlets e.t.c ive done with the stuff mind :-)
	Threads: 127
33
		Pump is back together and on the car now, but thanks for the suggestions - caustic soda, christ almighty, cleaned the inside of an exhaust with that once, exciting stuff.
Was just going with what I had lying around, but will put my hand in my pocket and try carb cleaner next time, though thought soaking diesel for a couple of days should have done the job.
	Threads: 3
		TFR the heavy stuff, caustic soda (2 baths) first bath will go black and just remove dirt but does very little to the shine on the alloy, second bath will make the alloy spotless ;-)
	Threads: 8
Car Model/Spec: ventian green p2 d-turbo
		i used petrol to clean my engine before i put it in was a great job
	Threads: 22
5
Car Model/Spec: Bmw e36 328i coupe
		I normally use petrol tbh nothing seems to work as well
