Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
Hey,
Im having a problem and need help diagnosing it!
I can hear where it is - drivers side - and symptoms consist of an annopying 'clinking' when going over bumps or up a curb...
It sounds similar to when you have a screw in a can - and you shake it - it makes that type of noise.
I was initially told it was the P bushes so i've got some new ones to fit tomorow, but i had a look today and everything 'looks' intact?
Anyone got any more suggestions please???
Phaes 1 GTI 6 - Onyx Black
Threads: 376
38
anyone?
Threads: 171
46
usually when hitting bumps go to suspension, top mounts wishbone bushes and ARB? but its usually more of a knocking then a tin can thing
Threads: 376
38
this is what i was thinking...
its sounds too 'clinky' to be anything 'big'. ive already replaced the top mounts...
anything visual to look at when going around the ARB and checking the bushes?
Threads: 171
46
give it a poke, make sure it doesnt move too much
i do remember a while ago someone went into the garage with a knocking described similar, turns out it was a stone/rock that got caught up in the sill somewhere so when he went over a bump the stone jumped about and knocked on something haha
81
I had a tinny rattle from the back going over bumbs etc which i thought was the exhaust heat shield wobbling. Turned it out its that protector disc on the inside of the rear disc brakes... its rusty as feck and its only got one bolt so it wobbles around and hits the disk now and again... should probably get it fixed but its doing no harm :/
Threads: 448
51
Sounds like wishbones bushes too me. Mine used to do it. Sounded like nuts and bolts in a can attached to the bottom of the car. It was ridiculous
Threads: 169
91
Drop link?
Could be anything down there really, jack it up, grab a handful of everything and tug away until you find something.
Giggedy
Threads: 55
When I had this I changed everything, ball joints drop links track rod ends and found out my top mount was loose
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
Threads: 376
38
holy revival!
This was sorted a while ago, but thanks for the concern
it turned out to be a dodgy strut top mount bearing
