Threads: 581
195
My cars going in tomorrow for a full exhaust so I spent the weekend fitting a new manifold. Didn't go to plan but either way, the car is all back together minus a cat.
I needed to bleed the coolant as I had removed the heater matrix pipes to get the manifold in. I've placed the cat in place where it would sit but there's no fire ring in the cat so it's not sealed. I've started the car to try and bleed it and it's running between 3-4k. Please tell me this is because of a lack of back pressure through the exhaust?!?
Can't even bleed the coolant as the water pump is not sounding at all happy at them sort of RPMs. I've got it bled as best as by blowing through the over flow and covering the cap.
I did have the inlet off but I'm sure this is all back on where it should be!
Please help and tell me once the new exhaust is on it will run fine?! If not, what could be causing it?
Thanks and sorry for the essay!
Threads: 541
124
Is your throttle shutting fully would be the first check IMO
Inlet manifold bolts are 20nm or 15lb/ft according to haynes
Threads: 22
Car Model/Spec: 306 1.4
As dum dum said check that. When my exhaust was off, and also changed to make it more free flowing it didnt change the revs! Are all pipes connected properly with no air leaks?
Threads: 581
195
Just been out there and had a look with the faithful snap on led torch and noticed there was a tiny gap between the manifold and head. Had it off within 5 minutes and there was a tiny bit of the old gasket stuck on the manifold. scraped it off, all bolted back on and it's fine now. Just sounds shite with no cat on it lol.
Panic over. Cheers guys!
Threads: 29
4
Sounds like you left a pipe off the inlet and it's leaking vacum.
Threads: 581
195
KrisB Wrote:oh, too late
Haha cheers anyway mate.
Oh and just to say, I drove over my bloody snap on torch. They are proper solid. Just a few marks and scratches!
Threads: 22
I need to get one of them! Glad you have sorted it mate!
Threads: 541
124
Niall your right they are proper solid, mines been in puddles and engine oil and repeatedly dropped from over 6ft (I use the magnet and sit it on the top of my bonnet when im working to light the engine bay and keep ending up knocking it off with my head)
I did have a look for more of the torches but they didnt have any.
Threads: 29
4
I need to get me some rechargables for my torch!
Threads: 581
195
Dum if you ever go back and they have some more, could you get me another?
Threads: 289
92
Car Model/Spec: Phase 17 R26
I'm pretty sure I've seen them again in Watford Costco since...if I go at all this week then I'll grab a couple.
Threads: 581
195
I'll buy one off whoever goes and gets them lol. Want one for the car and one for toolbox
