PAS pipes
PAS pipes
I need both pipes that come off the PAS pump on a non air-con d turbo.
Would be great if I don't have to go to the scrappy for them!
[Image: 20120704_212316.jpg]
Ben,
Currently dismantling a '94 XRDT (non-AC), I presume they'll be similar. I'll try to take some photos this evening and post.
[Image: 2306s.png]
The Old_______and_______Slight Less Old
Excellent that'l be what I need, I presume the pump is below the alternator? And one pipe goes up to the fluid tank and the other goes under the sump, to the steering rack I should think?
Yes to the PAS pump being below the alternator, 1 pipe from tank to pump and the other then disappears down the front of the block and then aft under the sump in the general direction of the steering rack.
[Image: P1040089_zps5369bb75.jpg]
Sounds like you have the same set up as me. I've PM'ed you with a few more phots to confirm same set up.
Smiley
[Image: 2306s.png]
