18-09-2012, 03:14 PM
I need both pipes that come off the PAS pump on a non air-con d turbo.
Would be great if I don't have to go to the scrappy for them!
PAS pipes
19-09-2012, 11:08 AM
Ben,
Currently dismantling a '94 XRDT (non-AC), I presume they'll be similar. I'll try to take some photos this evening and post. The Old_______and_______Slight Less Old
19-09-2012, 03:41 PM
Excellent that'l be what I need, I presume the pump is below the alternator? And one pipe goes up to the fluid tank and the other goes under the sump, to the steering rack I should think?
19-09-2012, 06:21 PM
Yes to the PAS pump being below the alternator, 1 pipe from tank to pump and the other then disappears down the front of the block and then aft under the sump in the general direction of the steering rack.
Sounds like you have the same set up as me. I've PM'ed you with a few more phots to confirm same set up. Smiley The Old_______and_______Slight Less Old
