hdi exhaust, tuning
Just wandered as i have removed the cat and middle box,
If i used the middle box as back box will the back pressure be affected??.
I had a 406 2.1td and my friend tweeked the turbo a little bit improve boost
is it possible on the hdi lump?.
Is there a good company to for a remap?.
Can i use a 406 intercooler?.
Sorey for all the questions.Blush
f*ck back pressure, that's for pussy fuel lol on a derv you just want to get rid of the exhaust asap
[Image: D09D6F9F-29DB-4EEF-9767-649F53E83571-170...0D4BFD.jpg]
No boxes atall FTW
No boxes and side exit FTW Smile
Sent from my BlackBerry 9800 using Tapatalk
^^^ trudat.
(04-09-2012, 09:05 PM)Connor Wrote: f*ck back pressure, that's for pussy fuel lol on a derv you just want to get rid of the exhaust asap
It's actually down to the turbo, turbo engines go better the less back-pressure you have. Less restrictive exhaust will mean quicker spool, better maintaining of boost at higher revs, generally more responsive, etc.
Bear in mind that you need one box in the system for it to be legal, although you don't need the cat.
Swapping the back box for the middle box will affect the back-pressure - it'll reduce it as the midbox is about as unrestrictive as they come.
For a remap you want to talk to MrWhippy, pro_steve or TB206HDi.
You can tweak the turbo a bit, but it's not recommended before you get an intercooler. These engines have quite small turbos from the factory, so increasing boost will also be running the turbo past it's peak efficiency and cooking your intake charge, which will cost you most of the power you will have gained from upping the boost.
You could use the 406 intercooler, but for the amount of effort you've got to put in, you may as well do it properly. Have a look in the HDi, guide and project sections for ideas on how you can go about fitting a front-mount intercooler.
Thanks guys for all you comments. I am looking in to getting front mounted intercooler and remap.
Im not tweek turbo as i have heard some stories
as for the exhaust the one and only box i have will b going
once i fitted rear axle and towbar (i have a small trailer and trailer tent).
I will have to see how far the suspension drops when towing trailer tent as i do want to
lower mine.
(05-09-2012, 04:29 AM)Poodle Wrote: Bear in mind that you need one box in the system for it to be legal, although you don't need the cat. (ie if you take the last box out of your system it will be illegal, won't pass an MOT and leaves you open to prosecution/persecution from the police.)
Just in case you missed it the first time, fair play if you didn't.
i did try it but it was too loud might get a custom backbox from infinity or longlife
as i use the car for towing.
Did sound f***ing sweet tho
thanks for you comments
Heh heh they do sound sick without boxes, really want a side-exit for mine... nom nom nom...
Nice spare.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Side exits with no box's sound epic when flooring it past nice high walls and people with windows down
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
(11-09-2012, 08:34 PM)HDIkyle Wrote: Side exits with no box's sound epic when flooring it past nice high walls and people with windows down
That would sound epic
(10-09-2012, 08:08 PM)Poodle Wrote: Heh heh they do sound sick without boxes, really want a side-exit for mine... nom nom nom...
SmileSmileSmileSmileSmileSmileSmile
Is there a guide to de egr or a blanking plate to buy/make??
