Threads: 171
46
Does it do it when its warm /cold/on start up?
Threads: 94
Used to be when cold and on start up now its doing it when its warm.. Any ideas? Someone else said injectors
Threads: 29
4
Dirty injectors most likely mate.
Threads: 94
Yeah thats exactly it puglove! Still reckon dirty injectors kris?
Threads: 170
5
Car Model/Spec: xud 1.9 dturbo
id say injectors too. mabe clean the filter in the sender unit too.
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 91
12
Car Model/Spec: 306 D Turbo
Yea you could try some redx or something. I tend to wait till the fuel light comes on then tip in the whole bottle then take it for a good thrashing. Or just chuck a litre of perv in to the tank!
Threads: 94
5er of petrol put in with plenty of diesel in the tank, haven't got a chance to run it all through yet but the problem is after getting worse.. If i let the revs drop while driving the car cuts out.. Anyone any ideas? Or should i just get the injector done?
Threads: 94
Dont think so.. Need this sorted for tomorrow ideally..
Threads: 30
3
Car Model/Spec: Peugeot 306 XRDT
05-09-2012, 08:50 AM
(This post was last modified: 05-09-2012, 08:56 AM by 306__xrdt.)
It could be air getting in to the dieselpump a small leak in the dieselpump.
Iff not it could also be the timing is wrong, didd you changed the glow plugs?
Always bay bosch glow plugs or ngk but bosch are preffered.
I hade some brake flued in the dieseltank and itt runs much better now, the problem is with diesel injector clean bottle it can dry out the injectors/dieselpump and then there is less friction in the camber, dieselpump.
What you can do is use diesel injector clean and after that trow in some 2 takts oil.
It should run smooth but hey best is off course clean the injectors while taking it out.
I have seen some treads how to clean injectors also on youtube a peugeot 306.
So good luck and have a nice day.
