Clutch cable
Clutch cable
Hello all 306oc, well yesterday me clutch made to loud sounds and now its bitting hight now ive had some one look at it and its not slipping they have said it could be the cultch cable any one got any idears how to change them ive done one on my 106 but i have got no idear where the 306 one run lol Blush . Thanks rob
Good question..... Anyone have a guide as I can't find one on this site? I'll be fitting my new cable to my car Wednesday and never done one before my self.
So im not the only one then lol
Cutch Tongue
I hope you haven't got air con...or a big HDi engine in the way! Its a right pain in the arse!!
Heres a guide Niall done....but it would've been so much easier on his 1.8 than the HDi!!!!!!! http://306oc.co.uk/forum/thread-844.html
(27-08-2012, 01:37 PM)Toms306 Wrote: I hope you haven't got air con...or a big HDi engine in the way! Its a right pain in the arse!!
Great that's me screwed!
Haha, allow plenty of time, and get a mate to help. It is a PITA, but if me and SRowell can manage it I'm sure anyone else can! Big Grin
snap mate woops Blush
Its an awful job on the hdi, turbo and ac pipes all in the way. there is another guide on 306gti6 too. Im doing mine and can't get the rubber back onto the hole, need to cut my ac pipes out i think!
if you use a BFO lever bar to pull the ac pipes out the way, it pops in easy. i used a pry bar and a chisel to get enough leverage. you need pull them out about 2 inches, if not more. unclip them from the bulkhead, and dont worry about breaking them, theyre flexible enough
(27-08-2012, 10:32 AM)rob-306hdi Wrote: Hello all 306oc, well yesterday me clutch made to loud sounds and now its bitting hight now ive had some one look at it and its not slipping they have said it could be the cultch cable any one got any idears how to change them ive done one on my 106 but i have got no idear where the 306 one run lol Blush . Thanks rob
Sounds like the auto adjuster mech has gone, try stamping on the pedal quickly a few times, if not any better just replace it. Easy job, dont see why everyone complains...
cheers mate Smile
(28-08-2012, 02:18 PM)samass Wrote: if you use a BFO lever bar to pull the ac pipes out the way, it pops in easy. i used a pry bar and a chisel to get enough leverage. you need pull them out about 2 inches, if not more. unclip them from the bulkhead, and dont worry about breaking them, theyre flexible enough
Doesn't work like that on the HDi.....you have space to get your hand to the bung OR to bend the pipes out the way.....there isn't space for both lol, engines too damn big!
Its the bloody EGR valve in the way.
(28-08-2012, 10:11 AM)DaveW Wrote: Its an awful job on the hdi, turbo and ac pipes all in the way. there is another guide on 306gti6 too. Im doing mine and can't get the rubber back onto the hole, need to cut my ac pipes out i think!
exactly this! Everything is in the way!
So sam and toms done it on the hdi quick tips on getting it done.
As some off you know i do not touch the engine of my car that's all my dads job. But he's on holiday and I need the cable done before Saturday (trax) so I'm doing it my self tomorrow.
Its just really fiddly to get it back through the bulk head under the aircon pipes. I find it easier with two people tbh thats about the only tip i have.
Don't forget to tie a shoelace or something to the old one before you pull it out, its a right lady garden to get the new on in the hole if you don't have any hair around it.
Sorry, if you don't have the string to pull it back through Tongue
Definitely that ^^^ and make sure its something strong......a string of pubes would most probably just break. Tongue
But seriously, the only difficult part is getting the pedal clip throguh the hole, then getting the grommet/bung back in properly. We didn't get the bung back in properly yet, just couldn't do it....but as were dropping the gearbox for a clutch change, we'll just rock the engine forward to push it back in (if we remember!). The pedal clip bit was most certainly easier with 2 people, one in the car pulling on the string tied to it it, and one n the bay, crowbarring the AC pipes and pushing the cable roughly in the right direction (you can't actually see the hole so it's all done by feel!).
Right so what you mean is inside the car tie the string to the white clip, then under the car pull the cable out then tie the new cable to the string and pull it from inside the car?
Yep, spot on.
I still have the string from sams hoody tied to line, never tool it off lol
Yeah the hole is so small tho, you can remove the fusebox panel and then take out bit of the air ducting to get abit of a better view of the pedals and the hole.
This is apparently the way to get the best view of the clucth cable hole....... Big Grin
[Image: EML003.jpg]
lmao
actually, pretty much what i did!
Haha, won't catch me doing that, I go dizzy just laying down never mind upside down lol. Tbh its not too hard to see after removing the cover and duct, and with a good torch sitting on the ground outside the car, I found I could see fine. Smile
Well start of the day was just terrible. Starting jacking car up got it on first axle stand no problem. Come to raise other side and guess what..... My driveway started collapsing and my car falling over. Just got hold of the car. Shouted my mum to get my next door neibour and sorted that put an got a tow down to my uncles garage who has a pit. Much safer. Just trying to get the clip through the bulkhead now.
My pedal has no spring to it. It's just drops to the floor? Is that cos the clips off it?
Good old fashioned pit.... Umm too tall for it!!!
yea the pedal is held up by the cable, so no worries there
Ok good. See what you mean by the who. Got the air duct out but still no use. Got a mate coming when he's finished work so should be a help then one thread as one pulls. Smile
Doing ok though to say I haven't relied on my dad whoop Smile
I've come to a solution.... Samass can I borrow some of your lube.... My arms are too fat.
Right I'm in... How do I adjust it?
It auto adjusts....
  Clutch Cable - 306 HDI year 2000 steve1001 10 7,678 25-10-2021, 06:38 PM
Last Post: Mighty306
  clutch cable fork pug306driver 9 5,151 26-01-2016, 09:00 AM
Last Post: Toms306
  306 manual clutch cable 306clot 14 10,096 02-10-2014, 01:46 PM
Last Post: 306clot
