Threads: 150
14
Car Model/Spec: 306 HDI
So I know this is a 306 forum blah blah but I thought I would ask anyways.
my mums vw sharan is having a brake problem, the light keeps flashing on and off every few minutes. Brake fluid levels are fine with no obvious leaks.
am I missing something obvious here or what?
cheers
306 HDI, soon to be XUD
Threads: 87
31
Given 1 thank(s) in 1 post(s)
Is it brake pad wear sensors maybe?
Threads: 150
14
I did wonder that will have a look, cheers
Threads: 386
87
It is the pad warning light or is it the handbrake light flashing on?
Threads: 581
195
You can get creams for vag problems from the chemist you know?
If it has pad wear sensors, check the wiring to them for broken/damaged wiring.
Threads: 42
2
as said before check the pads if they are low, if they have loads on them (more than 6-10mm) then the hand brake switch or wiring may be at fault. pad wear sensor lights are normally orange (warning) but the hand brake/low fluid level light is red (danger)
Threads: 73
6
Car Model/Spec: Shitbox Polo 1.0
If it's a case of blue waffle she really needs to get to the doctors ASAP as it's not only mentally disturbing but also quite smelly I've heard.
Failing that ABS sensors tend to come off on the Sharan quite easily so I'd have a fiddle...With the ABS sensors, not the blue waffle.
Member of Team Rather be Gay than Ginger
Member of Team Holey Engine
Threads: 93
8
Car Model/Spec: Stock HDi Meridian & Mk2 MX-5
Yeah, I'd head straight to the gynocologist if I were you buddy, these things are best left to the experts.
Threads: 130
82
Car Model/Spec: 106 GO-NAD
im an amatuer gyno, want me to take a look?
