Gti6 Clutch on XUD
As there both Pull type clutches what power can the Gti6 clutch take? Do people that run high boost chargers run standard clutches on the Gti6?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
(07-08-2012, 06:52 PM)HDIkyle Wrote: As there both Pull type clutches what power can the Gti6 clutch take? Do people that run high boost chargers run standard clutches on the Gti6?
The gti6 clutch and xud clutch are the same.
My gti6 ran 275bhp on a standard luk/Valeo, but didn't have much torque.
Remember, it's torque that destroys them.
[Image: 704e7db1.jpg]
Ok cheers I have a brand spanking new gti clutch so was going to fit that to my DT only going to be running t2 with 11mm and fm so not mega power so should be fine. Was not sure if they were designed to the engine type that's all. Cheers Dan
Blaze 1.6 Dead
You'll be fine with a DT clutch...
I think the GTi6 clutch has a very slightly heavier pressure plate... but it's negligible.
I know but that then means buying one where I have a gti one in the shed
Blaze 1.6 Dead
