door speakers
door speakers
got some fli 4.5" (i think) i want to stick in the door. had a look at the standard ones yesterday and there is that yellow plug into the standard speaker. how do i swap it for my flis? cut the yellow plug off then attach the wires?
on the flis its just a metal bracket shaped like a B - 2 small holes that wire just wraps around.
also the same for speakers on the parcel shelf?
You can pull the yellow connector apart iirc and inside there are spade connectors that will pull out with a bit of a tug, but i usually just cut the plug off and wrap it round the terminal on the speaker works fine
Team Doesn't own a 306
1... 4.5" wont fit. iirc its 6.25".
2.... cut blocks off and get some spade connectors.
Might b 6.5 I'll have check lol. Thanks guys
too small =[ anyone recommend some good speakers that are a straight swap?
what sort of money are we talking?
i got these in mine and dont sound to bad for budgets.
http://www.ebay.co.uk/itm/FLI-FI6-F3-6-5...3a5d9b8417
i might get them Smile
straight swap? just stick the wires on them?
got a set of these in mine
http://www.ebay.co.uk/itm/Alpine-SXE-172...255dd22047
not too bad stop the distortion when you turn it right up Big Grin and these were a straight swap even the plugs were the same i think
but you can find them cheaper elsewhere Paid about £24.99 from halfrauds on offer
So sound nice at high levels? Might have to get some
(29-07-2012, 10:06 AM)rocker8742 Wrote: got a set of these in mine
Another vote for these, they dont handle the bass too well, but when coupled with a sub, they're ideal. Smile
Argh the music I listen to is all about bass and I cant be bothered with subs and amps etc Sad
tbh its easy enough to get a sub and amp package and run the cables
