10-05-2012, 11:18 AM
what level adjusters do you use with the phase 3 lights
thanks
thanks
phase 2 to phase 3 lights
thanks
10-05-2012, 11:29 AM
if going on a ph2 car then the ones from your ph2 lights
10-05-2012, 12:08 PM
ok thanks
10-06-2012, 09:02 AM
or keep the p3 ones in and use the manual overide hahaha
yeah thats how i roll
10-06-2012, 09:17 AM
Joe Wrote:or keep the p3 ones in and use the manual overide hahaha Or for the 20 seconds that it takes to do you might as well swap them over, if you have a few people in the back or a lot of stuff in the car it becomes a bit of a PITA getting out of the car with an allen key and opening the bonnet to readjust the lights while your driving.......................
10-06-2012, 11:30 AM
I used ph3 adjusters for my crystals on my ph2.5 car and they work fine..
Parts bin win? ![]() Dturbo GT2259s build thread; http://306oc.co.uk/forum/thread-3692.html Daily driver; 330d Msport (doesn't blow up!)
11-06-2012, 11:16 AM
Yeah, parts bin specials use the later style connectors... But I've also a feeling some part binners use twin optic frosties...
11-06-2012, 11:29 AM
Ruan Wrote:Yeah, parts bin specials use the later style connectors... But I've also a feeling some part binners use twin optic frosties... I had them, so yep And as others have said - it takes literally 30 seconds to swap over the connectors. Definitely worth it.
21-07-2012, 10:59 AM
I put crystals on my ph 2, swapped the adjusters and they don't work
21-07-2012, 06:20 PM
(21-07-2012, 10:59 AM)bowers Wrote: I put crystals on my ph 2, swapped the adjusters and they don't work Thats because you havent put them back in properly, I just swap the top part of it over instead of the whole thing, much easyer. will get some pics On the parts bin subject. my old 2.5 Gti6 had ph3 adjusters and twin optics in a ph2 head light, im guessing all ph2 head lights with a ph3 adjuster is a twin optic.
21-07-2012, 07:06 PM
What you mean top parts? I just swapped the pArt that twists and then pulls out
21-07-2012, 11:58 PM
did you make sure you got it clipped back into the reflector?
22-07-2012, 09:32 AM
The ball popped into the clip, then I twisted it to lock it
22-07-2012, 09:58 AM
(21-07-2012, 07:06 PM)bowers Wrote: What you mean top parts? I just swapped the pArt that twists and then pulls out The bit the twists out has a cover/plug over the top of it you can just pop that plug bit off and put the one from the ph2 on , i will get some pics today as its hard to explain. I do it the way because i cant ever get the ball back in any sence or in the correct position
22-07-2012, 10:11 AM
Will try to have a look today
22-07-2012, 07:00 PM
lol forgot pics again! will try to remember when i get in tonight
22-07-2012, 08:33 PM
Hahaha doooo it
24-07-2012, 11:15 AM
any luck?
31-07-2012, 12:19 PM
Hahaha c'mon pug
Pic are downloading as we speak
Right at long last this is what i was chatting about swapping ![]() ![]() ![]() And then just dap the others on, and hey presto no need to realine the lights
01-08-2012, 03:44 AM
So which part do I actually swap mate?
01-08-2012, 04:29 PM
The bit that is in my hand simply pop them off both lights (ph2 lights & ph3 lights) then pop the ph2 ones onto the crystals, the ph2 on will be brown,
02-08-2012, 11:50 AM
So take the back off the phase 2 ones and put em on ph3 ones. Sound
02-08-2012, 11:53 AM
They are brown and a ph2 but yes. You only need to unclip the top half rather than take the whole thing out.
30-08-2012, 09:23 AM
Finally got round to doin this yesterday. Hasn't worked. Both sets of my adjusters look exactly the same too. Tried swapping everything over and tryin every combination but hasn't worked.
They work cuz moved the switch without the adjusters in the light and they were moving. Dunno what to do?
Take pictures of the two adjusters you have?
30-08-2012, 10:20 AM
30-08-2012, 10:22 AM
They are the ph3 ones, do you have the brown ones?
30-08-2012, 11:24 AM
They are all the same mate. No brown ones. Took a pic of one that was in the ph2 lights, and a pic of one of the ones out of the crystals
| Phase 1 (?) wheel into Phase 2 ? | Sinbad | 0 | 2,065 |
22-08-2021, 11:42 AM Last Post: Sinbad |
| component speakers for a phase 2? | DonGonzo | 0 | 1,984 |
16-11-2020, 07:41 PM Last Post: DonGonzo |
| 5 door phase 3 interior parts for sale | Teeharv | 1 | 3,660 |
15-03-2019, 01:03 PM Last Post: Teeharv |
