phase 2 to phase 3 lights
what level adjusters do you use with the phase 3 lights
thanks
if going on a ph2 car then the ones from your ph2 lights Smile
Team Orange Engine Bay
ok thanks
or keep the p3 ones in and use the manual overide hahaha Wink yeah thats how i roll Tongue
Joe Wrote:or keep the p3 ones in and use the manual overide hahaha Wink yeah thats how i roll Tongue
Or for the 20 seconds that it takes to do you might as well swap them over, if you have a few people in the back or a lot of stuff in the car it becomes a bit of a PITA getting out of the car with an allen key and opening the bonnet to readjust the lights while your driving.......................
I used ph3 adjusters for my crystals on my ph2.5 car and they work fine..
Parts bin win?
[Image: brokendown-1-1-1.jpg]
Dturbo GT2259s build thread;
Yeah, parts bin specials use the later style connectors... But I've also a feeling some part binners use twin optic frosties...
Ruan Wrote:Yeah, parts bin specials use the later style connectors... But I've also a feeling some part binners use twin optic frosties...
I had them, so yep Smile
And as others have said - it takes literally 30 seconds to swap over the connectors. Definitely worth it.
I put crystals on my ph 2, swapped the adjusters and they don't work Sad
(21-07-2012, 10:59 AM)bowers Wrote: I put crystals on my ph 2, swapped the adjusters and they don't work Sad
Thats because you havent put them back in properly, I just swap the top part of it over instead of the whole thing, much easyer. will get some pics
On the parts bin subject. my old 2.5 Gti6 had ph3 adjusters and twin optics in a ph2 head light, im guessing all ph2 head lights with a ph3 adjuster is a twin optic.
What you mean top parts? I just swapped the pArt that twists and then pulls out
did you make sure you got it clipped back into the reflector?
The ball popped into the clip, then I twisted it to lock it
(21-07-2012, 07:06 PM)bowers Wrote: What you mean top parts? I just swapped the pArt that twists and then pulls out
The bit the twists out has a cover/plug over the top of it you can just pop that plug bit off and put the one from the ph2 on , i will get some pics today as its hard to explain.
I do it the way because i cant ever get the ball back in any sence or in the correct position
Will try to have a look today Smile
lol forgot pics again! will try to remember when i get in tonight
Hahaha doooo it
any luck? Wink
FFS im usless at this
Hahaha c'mon pug Wink
Pic are downloading as we speak
Right at long last this is what i was chatting about swapping
[Image: 2012-07-31181607.jpg]
[Image: 2012-07-31181554.jpg]
[Image: 2012-07-31181536.jpg]
And then just dap the others on, and hey presto no need to realine the lights
So which part do I actually swap mate?
The bit that is in my hand simply pop them off both lights (ph2 lights & ph3 lights) then pop the ph2 ones onto the crystals, the ph2 on will be brown,
So take the back off the phase 2 ones and put em on ph3 ones. Sound Smile
They are brown and a ph2 but yes. You only need to unclip the top half rather than take the whole thing out.
Finally got round to doin this yesterday. Hasn't worked. Both sets of my adjusters look exactly the same too. Tried swapping everything over and tryin every combination but hasn't worked.
They work cuz moved the switch without the adjusters in the light and they were moving. Dunno what to do?
Take pictures of the two adjusters you have?
They are the ph3 ones, do you have the brown ones?
They are all the same mate. No brown ones. Took a pic of one that was in the ph2 lights, and a pic of one of the ones out of the crystals
  Phase 1 (?) wheel into Phase 2 ? Sinbad 0 2,066 22-08-2021, 11:42 AM
Last Post: Sinbad
  component speakers for a phase 2? DonGonzo 0 1,985 16-11-2020, 07:41 PM
Last Post: DonGonzo
  5 door phase 3 interior parts for sale Teeharv 1 3,661 15-03-2019, 01:03 PM
Last Post: Teeharv
