hello everyone, just recently passed my test at 17 and for my first car, 306 D TURBO ! sigma blue p1 306, running @ 18psi with a bosch pump, with a d8a lump with 87000 miles, and i cant get enough haha, anyway a few of my friends said to get myself on a forum just incase anything goes wrong and i need some advice, so i have done when i bought it the rev gauge didnt work, and now its really doing my head in, lol would anyone know how to get this working ? thanks
15-07-2012, 05:28 PM (This post was last modified: 15-07-2012, 05:30 PM by puglove.)
Welcome along mate. Thats a very nice DT you have. Dont listen to what any one says about the spoiler. Those sp ones are mint.
As for the rev counter. You will more than likely have to replac the clock which means loosing you genuine mileage. So what id sugest is you get yourself a seperate rev guage like a boost guage style as it would be a shame to loose the mileahe on such low mile ph1 DT
Also where are you located?
thanks all, glad you like my car as much as i do and i am from barnsley near sheffield, thankyou for the advice about the clocks, ill have a look on ebay, thanks again !
Heavy clutch was an optional extra on these, lucky you
naa kidding its design fault, welcome to the world of french.
Get involved with some of the local members/meets , I'm normally up in Bradford during uni term time if you need help/tools
As for the Rev counter not working, have you checked that the sender is working properly? Or come to think about it that its even plugged in? because that is where I would start personally as its the easiest thing to check and change
As far as the clutch cable goes, it could be a stuck auto adjuster thing or dry bushes on the release fork in the gearbox, I would start with the car switched off stamping on the clutch pedal and then stepping off it so that it slams back to the top, repeat this 5-10 times and see if it makes any difference (again easiest and cheapest thing first)......hope this helps
Welcome along bud. Your car looks sweet. I had a sigma ph1 for my first car when I was 17. Try changing the rev counter sensor first. Mine didn't work and that's what I changed to fix it
