Adjusting hot idle
Hot ideal screw is backed all the way out and my idle is at 1000. Fuel isn't turned up that much really.. Hot and cold idle is the same.. Want it to be around 850 if possible! Any ideas? Thanks Smile
Wait for the engine to get "HOT"??
Was at 85 degrees ginge Smile
Any way of adjusting the bar the throttle arms rests on?
Then it's your max fuel, if your idle is all the way out, it's not going to go down much further. Make sure you've dropped the pin 'pushing' the throttle arm, there could be some play left there.
If not, and you're still concerned with the idle, drop the fuel, if not, enojoy a 1krpm, it's not THAT bad Smile
Ill have a look now later Smile Ah yeah i know its not that bad just like to have it a bit lower lol Thanks fellas Smile
  Manually adjusting clutch cable for xud bashbarnard 21 14,475 21-03-2016, 04:26 PM
Last Post: bashbarnard
