Gearbox gear change?
Would it be possible to have the 5th gear from an HDI box in an XUD box? I don't have a spare one to poke around otherwise I would.
Ta
just fit a HDI box Smile
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Hdi box has longer ratios so doesn't keep you on boost so much though
Which is why I want an xud box with hdi 5th. I want an xud box for when I'm going through the gears but then a lower rpm when at a steady speed.
How about the final drive from an XUD fitted to a '6 box instead? Big Grin
[Image: MIRKxNP.jpg]
HDI and DT box are the same bar the final drive giving the longer ratios throughout the box.
And FYI the 6 box has a longer final drive than both the HDI and DT IIRC, if not its not much shorter as the hdi and the 6 are around the 3.8 region IIRC.
[Image: sig.jpg]
(11-07-2012, 08:08 PM)Chris Wrote: HDI and DT box are the same bar the final drive giving the longer ratios throughout the box.
Beat me to it. The 205 DTURBO box, 306 dt and HDI have the same gears just a different final drive.
If you want short is gears get a '6 box and some 20" rims lol
Troll out.
Stage 2 XUD Sedan
  gearbox change snooker147 3 3,469 29-03-2013, 06:12 PM
Last Post: Danny2009
  No turnover(gearbox change) pugtk 2 2,570 21-02-2013, 10:25 PM
Last Post: pugtk
  Clutch and/or Gearbox change 205 XUD silverzx 8 8,604 16-02-2013, 07:21 PM
Last Post: silverzx
