HRW Switch, OEM Clarion CD HU
Wanted: HRW Switch, OEM Clarion CD HU
As above if anyone has either-
Heated rear window switch which goes on the centre console. There's a few on ebay but none ending soon enough for me!
Also after a standard Clarion Headunit, the CD type. Currently rocking the tape deck and want rid! Ideally with code, but if not does anyone know where I can go to get hold of the code?
Also need a passenger wheel arch lining
Phase 3 rubstrip from a 3 door, passenger door side and the small piece from the front wing.
Please help if ya can!
Forgot to add, will also need the volume control stalk with the yellow plug on the end!
[Image: Sig500x130.png]
I might have the OEM headunitx will have a look
306 HDI, soon to be XUD
I have heated window switch in the shed. also a radio stalk from a phase 1 will check the plug on it later and see if its the same Smile
The plug on the sterio control is black with a little yellow square on it?
E rub strips are very cheap from pug and come with all the clips. Just give them a blast of paint and job done!
Cheers guys,
The correct stalk I think is a small square yellow one, I'll post a picture when I'm next on a pc.
Niall, help me work out the part numbers please! I have access to service box, I think the correct one is 8545 followed by two letters...
If the stalk is wrong i may have the correct one on the 6 as its not being used Smile
I think the one i have is wrong
found this on ebay tho if it helps Smile
http://www.ebay.co.uk/itm/306-97-on-1-4-...415b95c46f
I have now acquired everything but the rubstrip, all from one bloke on 'the other site'.
What a hero.
  CLARION STEREO PU2294 now sorted NOSE 7 5,409 16-12-2015, 09:52 PM
Last Post: NOSE
  Wanted: Original 306 cd player clarion headunit ozonehostile 4 2,564 24-07-2014, 01:01 AM
Last Post: mcglynn
  SOURCED Clarion PU-2293A Dangti6 1 2,304 02-05-2013, 12:30 PM
Last Post: Dangti6
