Mysteries... helpplease?
Sad
Hi all,
Just become the proud owner of a 1999 306 Cabrio 2.0Ltr I plan on bringing back to life  Inlove
I've found guides on how to rebuild the back axle (not sure if it needs it yet, the camber doesn't look too bad to me, maybe a degree or so out of vertical..?)
I found a Peugeot-made video on replacing / fitting and checking the roof, although it's in French  Confused  ...............  but my main query is where to find information on the engine, and in particular the cambelt, which will need changing immediately as it run only 25000Km since the last change, but the change was 8 years ago  TMI
From what I understand (?) there are two different types of 2.0ltr cambelt and cam pulleys - one with 3 bolts, the other with one, and one belt with X number of teeth and another with Y? (and if I understand correctly the tensioners change with the belts?)
So, if I take the cover off, which belt / tensioner goes with which pulley?
I've Googled my tail off but I come up with nothing worthwhile by way of how-too's or specifications, nor for that matter on front suspension, what to look out for - or usually suspect area for rust on these (although it appears fairly sound)
Can anyone help with links to / info on these items?
Thanks
Congratulations on becoming a 306 owner & welcome to the club.
If the rear beam is properly on the way out you'll start to get uneven tyre wear on the rear. If it gets that far the beam tube will probably be scrap though. If you don't know the history the only way to check if it's in need of attention is to strip it down. If you can get hold of a good secondhand or decent aftermarket tube (there are some on ebay) you don't have to worry too much about leaving it until it gets terminal.
I've never worked on a cab I'm afraid so know nothing about maintaining or repairing the roof.
As for the cam pulleys, yes there are two different types found on the 2.0 16v engine. They changed from the 3-bolt type to the single bolt in the second half of 1997. As a rule of thumb if you have the cast alloy cam covers they'll be the earlier 3-bolt type and the ones with the plastic covers will be single bolt. They changed them because there was a risk of cracking the pulleys from over-tightening the 3 smaller bolts on the earlier ones. The only real difference when it comes to a cam belt change is that you need to use a cam holding tool to aid with loosening / removal of the single centre bolt on the later engines. (Like this one .... https://www.ebay.co.uk/itm/Laser-Tools-2...SwQKdcsHJx)
As for tensioners & belt length, many engines were fitted with the manual tensioner. The manual tensioner uses 136 tooth belt. The automatic tensioner needs a 137 tooth belt. You can convert one to the other, but you would need the post for the manual tensioner to mount on if you were switching from an automatic tensioner. Some say the manual tensioner is better, but you'll have to 'feel' that the tension is correct. In the guide below (for a manual tentioner, 3 bolt cam pulley) they refer to a SEEM tensioner. SEEM units were a proprietory Peugeot thing & you won't now be able to find a tensioner tool that uses those units.
When you change the cambelt it's highly recommended that you change the idler, tensioner & water pump at the same time.
https://www.petrila.net/repair/2/406d8/i...eg0ik3.htm
It's worth being aware that the crank pulley with a rubber torsional damper (i.e. most of them) can't be fully relied on for timing the bottom end unless it's new. This helps explain how you can check http://www.306gti6.com/forum/showthread.php?id=164917. (It refers to a gti6 engine but the engine blocks and the procedure are the same).
I also have an original Citroen workshop manual for the XU10J4R (same engine as in the 306) in .pdf form but can't load it up here. It's very similar to the Petrilla guide tbh. If you'd like a copy I can sort out emailing it to you.
As for rust, you'll just have to have a good poke-about underneath. One major issue is floor rails having been used for jacking the front of the car. Other vulnerable spots are around the rear bump stops & the left rear wheel arch on hatchbacks / estates but don't know about the cabs.
Get yourself a copy of the 306 Haynes manual. It's pretty good on a lot of the suspension, brake & auxillary stuff. Re the front suspension it's the usual stuff that might wear. (Ball joints, top mounts, strut bearings, wishbone bushes, particularly the p-bushes on the 306).
Lets see if this works... an updated pic of the old girl taken yesterday
[Image: 239862959_10159260909268360_153146842816...e=61497182]
(26-09-2020, 11:35 AM)Mighty306 Wrote: Congratulations on becoming a 306 owner & welcome to the club.
I'm bleeding rude fornot replying to this - sorry Mighty! I think you may have seen elsewhere I'd forgotten I'd registered  Itwasntme
This was really helpful especially on the cambelt - now done. I will have to sit down and make a list of the stuff I've done to bring her back to life  Rofl
It's long.... very long....  Rofl
