Help pleaseee :)
Hey strangers. So ordering the parts for my 6 and stuck.. been looking at radiators and fans.. Both are knackered but not sure what make radiator to go for and my 6 only has one fan? Which doesn’t work of course. Am I better off just finding a breaker or buying new?
Free hangover cures!
Nissens.
I shall have a look thankyou Smile
Find the Nissens part number and search that on ebay and Amazon for the best price on the rad.
Fan's probably best to get good used from a breaker.
Do you have AC? I thought it was twin fans on ph2/3 with AC but maybe it is only ph3.
I don’t have a/c haha! It’s a ph1 with ph2/3 exterior
Oh, well in that case single fan is normal then. Wink
If you're only able to track down a double fan at a breakers I'm guessing the motors are the same as in the single fans n can be swapped over. Am sure someone can confirm?
as said above, get a Nissans, find the right part number and google it, Amazon is a good place to look, half the price of ebay for one for mine Smile
100% nissens. Dont accept anything else. I have been caught out before ordering one and being sent one of equal quality... which was shit and failed after 4 weeks.
If anyone has the part number please post it!
With the fan... either get original or fit a slimline one with a relay if you can work out how to do it. Should save on weight, look nicer and be easier to replace in the future.
(27-02-2018, 10:36 AM)Mighty306 Wrote: If you're only able to track down a double fan at a breakers I'm guessing the motors are the same as in the single fans n can be swapped over. Am sure someone can confirm?
Looking on Servicebox it appears two different makes of fan were used - Gate & ECIA.  The motors for the ECIA ones look to be interchangeable between single & double fans (for ph2/3) but the part numbers are different for the Gate models ......at least that's the case on the 16v XSi.  Am assuming it's the same for the GTi-6.
Once you get the Peugeot part number for the radiator from Servicebox you can find the cross-referenced Nissens part on here.  https://partinfo.org/
