08-11-2017, 09:01 PM
as above anyone got some tips, tricks and tools for removing the pins from the loom plug on the single socket ecus
any tips for removing ecu plug pins
08-11-2017, 09:17 PM
remove the screw, pull the inside section out, pull out the coloured slider keeper things out, then the pins will come out quite easily.
most of the later ones have a bit of rubbery plasticy crap moulded on the end which you'll need to remove.
08-11-2017, 11:02 PM
What he said ^^^^^^& Seem to remember they had a little tab which needs to be retracted for removal.
| Swapping 3 plug to 1 plug | bashbarnard | 6 | 5,008 |
25-02-2017, 05:16 PM Last Post: bashbarnard |
| Engine cover pins | Hdi and proud of it | 11 | 8,223 |
24-03-2015, 09:57 AM Last Post: Eeyore |
