206 2.0 HDI clutch
206 2.0 HDI clutch
I was driving my gf 206 and I've found that the clutch biting point is very high.
It's a hydraulic clutch so I don't think it can be adjusted?
I replaced the clutch a couple of year back and there hasn't been many miles put on it since.
Is there a way to adjust the clutch biting point?
Nope, automatic
as piggy says there is no way of adjusting it.
Bugger, thanks guys
Slave cylinder on its way out?
Pull back the rubber cover and see if it's damp.
Slave is good.
Sorry my description is a bit shit I meant really low as is in you push it down and the bite is almost where you release the peddle, if that makes sense?
I would prefer it to be higher, nearer the floor.
Sent from my Nexus 4 using Tapatalk
try bleeding it.
Ah that sounds more like air in system as above
Good shout, I hadn't even thought about it like that. That makes a lot more sense, I'll give it a go.
