Threads: 186
6
Car Model/Spec: Peugeot 306 2.0 HDI
Alright guys. I am having problems with the low speed fan. If I am sat for a while or after a hard drive and then I stop for a bit the temp spikes but no fans kick in :/ is this most likely the relays or fuses etc? Both fans work fine at full speed when I unplug the temp sensor.
Threads: 9
Car Model/Spec: HDi Meridian
Remove the front grill, in a triangular box, there's a bunch of relays. iirc, some of these control the fans and could be corroded.
There's also a loom fault, underneath the front bumper, water gets into the loom connection and corrodes.
Threads: 128
21
it might seem like a silly question but do the fans come on at all?
pull the temp sensor and see if the engine goes into emergency mode and throws the fans on
/Toseland
Threads: 202
58
Iirc he's already checked and they do come on at full speed
Threads: 465
114
Car Model/Spec: Vauxhall
as big K says check relays and loom plug on the fan cowl
Threads: 128
21
I missed that bit lol, quick read during a lesson (naughty me)
/Toseland
Threads: 186
6
Haha rebel.
Okay will try and have a look. I am struggling to remove the stupid plastic cover bit at the top of the rad. The part that's the same colour as the paint work. I don't really have the right tools to pop the clips out :/
Threads: 128
21
you don't have a screwdriver?
/Toseland
Lol, even a knife or spoon pops those out! The middle has to come out of the clip first BTW.
Threads: 465
114
if you are lucky you can prise the centre pin out to release the rivet
if you are unlucky you punch the centre pin into the panel releasing the rivet
and if like me get so fecked off with the stupid things you bin them and fit rivnuts so you can bolt the panel back on
Threads: 186
6
Ahhh that type of clip  I just beeb pulling at them thinking they are like the pop out type haha cheers  will go and have a look now
Or if you're the previous owner of my car you just whack in mismatched wood screws at jaunty angles in the hope of holding it on...
Threads: 186
6
09-05-2016, 02:10 PM
(This post was last modified: 09-05-2016, 02:27 PM by JTaylor2005.)
Well so far I have snapped the top of one so looks like I'm gonna be using wood screws as well  lol
None of them lived haha. All the tops just sheered off on them all lol
Still won't come off even with the clips out and the bolt removed
The hockey sticks under the lights might be holding it? Have fun breaking the tabs off those...
Threads: 186
6
Got fed up and washed the car instead haha
What temperature is it spiking to?
And by that I do not mean what temperature the dashboard says - I'm talking about what the ECU thinks as that's the temperature that the fans are controlled via.
Threads: 186
6
I have no pp2000 and no idea who has one by me so I can't check.
It's fully bled has a brand new decent thermostat so it must be the gauge that's showing too high I would think
As someone else pointed out, 306s are OBD compatible, so a Bluetooth OBD adapter and Torque on your phone and you'd be away.
Threads: 186
6
Threads: 70
10
Car Model/Spec: HDi Estate
I bought similar and it works fine
Threads: 101
Car Model/Spec: 306HDi 90 LX
(09-05-2016, 06:20 PM)JTaylor2005 Wrote: Sweet. One like this do you reckon?
http://m.ebay.co.uk/itm/Super-Mini-OBD2-...nav=SEARCH
do you know which windows it works with?
It goes, it stops (as reqd).
Hate Housework!
Threads: 186
6
Says android on it :/ phone??
Threads: 101
(10-05-2016, 03:48 AM)JTaylor2005 Wrote: Says android on it :/ phone??
bummer!
Hate Housework!
There are loads that work with an elm cable on windows as well. All my car programmes work on win10 except pp2k now.
Yeah, they're all ELM327 interfaces - you can probably get a USB one that will work easier with Windows and you'll just need an application which will work with an ELM327 interface. Tom can probably suggest something..
Threads: 186
6
Oh sorry it does work with windows by the looks of it but you will need a laptop with blutooth I suppose mate
Threads: 9
You don't need those clips for the grill... there's a bolt which holds it on well enough! haha
