engine wiring looms differences
question for the peeps in the know
ph2 and ph3 engine looms what are the differences?
ive found the Map sensor plugs to be differant and so is the power steering pressure sensor plug are there any more?
will a ph 3 loom plug into a ph2 car and work if you fit the correct plugged sensors or ph3 engine?
Ph2 MAP
[Image: 20150628_151757.jpg]
Ph3 MAP
[Image: 20150628_151918.jpg]
Ph2 PAS sensor
[Image: 20150628_154054.jpg]
Ph3 PAS sensor
[Image: 20150628_151934.jpg]
GTI6 Info
  Differences between xsara vts & gti6 engines? Matt-Rallye 11 10,303 01-03-2017, 08:50 PM
Last Post: welshpug
  Differences? underground375 1 2,028 16-12-2013, 11:04 PM
Last Post: miles
