01-11-2014, 11:45 AM
My cars being lowered and the lads just said it's about 60mm instead of 30mm will my 17 challengers still fit on 15mm spacers front and 20mm spacers rear or am I looking at arch mods now?
help required urgently
01-11-2014, 11:46 AM
ouch. likely tbh. Also depends how firm the suspension is setup. What TBs and springs are you using?
01-11-2014, 12:00 PM
Apparently 30mm spaxx springs that have now turned out to be 60mm on standard shocks at the minute but will be upgrading at Xmas to bilstein B4's
01-11-2014, 12:37 PM
60mm springs on standard shocks won't be a nice ride lol...
01-11-2014, 05:49 PM
(01-11-2014, 12:37 PM)Toms306 Wrote: 60mm springs on standard shocks won't be a nice ride lol...Can confirm this used to have 60s on my standard shocks. Its quite crashy. Im now on 40mm standard shocks and they are a lot better
04-11-2014, 10:50 AM
The ride isn't that bad but as said above I was planning on fitting 17" atlantis wheels from the 206 but now have stumbled on the fact I'm a lot lower than I wanted to be, I've had a look at the rims and on the backs they say 7jx17-28 so somehow need to work out the correct spacing to fit the 306 I went ahead and bought 15mm front and 20mm rear spacers but now believe they will be too far out the arch?? To fit on the lowered puf
04-11-2014, 05:08 PM
You'd need 10mm spacers, standard offset is 15-20 iirc
