Ideas
Ideas
Hello I use to own a tweeted xud until a con rod went through the block, desperately after enougher, I have a 1.4 ph1 3dr with alright spec and shell wondering if anyone one has attempted petrol to xud conversion and if it's possible, also seen a saloon with 210k miles on it fairly cheap wondering about opinions from more knowledgeable people,,, cheers
Can't see it being worth the hassle to be honest, you can pick up a diesel so cheap anyway whats the point in messing around with a silly conversion??
Its possible but to do it would be cheaper to buy a diesel one.
I'm biased but please don't break a saloon for a 3 door unless its a wreck!
yeh itd be easier just to buy a derv.
Yeahh thought about this a bit more now to be honest, I wouldn't break a saloon I'm not that cruel, just keep my eyes peeled for a average xud
I have no idea why people are saying it’s not worth it?
I would 100000% do a conversion if I had enough desire for the car.
Other conversions are particularly hard when going from petrol blocks to other petrol blocks with issues with driveshaft’s electrics etc, but the diesel will fit straight into the engine bay, apart from POSSIBLY the driveshafts, everything else can be used, you will need diesel engine mounts. Wiring is dead simple, exhaust will need to be made/bought as a stock DT, and a few hoses required. You’ll have issues with the clocks too.
I seem to remember a few of us doing a gti6 conversion to Dturbo on Ruans car in 1 day, and there were NO teething issues following, apart from the tacho….
Ph1xud loom and clocks and sorted.
If I had what you had....I'd turn the saloon into a 3dr xud boost mad monster!!
Subframe needs a mount changing from TU engine to XU/XUD.
Other than that it's a case of swap fuel filler neck and pretty much everything else plugs in.
To be fair it would be good but it's a lot of time and effort so think I will try and find a xud powered car and break my petrol, I assume the non turbo xuds have shit internals compared to the dt lump
Yea the non-turbo's are shit.
I know someone who caught AIDS from driving a non-turbo, true story.
(06-08-2014, 05:58 AM)Piggy Wrote: Ph1xud loom and clocks and sorted.
What I plan to do to my sedan Smile
Coversion are of course doable. Insurance can be got. If you like it go for it.
