25-07-2014, 10:45 PM
Basically i want a switch to manually turn the fueling ON when the ignition is live, a sort of very basic immobiliser,
now.. this switch i want to be special, essentially i want a switch like the one below but that only stays on if there is a live going to it (ie the ignition is on) and when the ignition is off it resets to the off position (so i have to turn it on again when i get back in the car). is this possible or is it possible to do this some way?
so... ignition on, switch on, start... ignition off, switch resets to off, ..
hopefully my screwed up mind made myself somewhat clear.
/Toseland
/Toseland
