boost load compensator
how is everyone running boost load compensator pipe with xantia inlet..??
I was thinking of getting a 8mm pipe alloy welded to the left side of the inlet or to one of the alloy boot pipes.... what you think
or even something like this - http://www.ebay.co.uk/itm/181303167188?s...1423.l2649
advise please
Some people use a tap and die set and just tap one in the side
I got 1 of them take off bits in the link and just drilled a whole in 1 of the silicone boost pipes. Does the job
  Boost compensator pipe sherman306 4 3,105 04-11-2013, 09:30 PM
Last Post: sherman306
  Boost compensator question... JayDub 1 2,222 30-05-2013, 06:41 PM
Last Post: 4WayDiablo
  Boost compensator pipe David 2 2,657 29-01-2013, 10:42 AM
Last Post: David
