19-07-2013, 08:53 PM
The Airbag and you...For MOT !!
20-07-2013, 12:08 AM
I thought that Connor but I took the dash out today and there was clearly a missing bulb and I looked underneath and it says air bag quite clearly
20-07-2013, 07:11 AM
Ignore that Stephen Peugeot do that to save money having to make multiple dials. Mine have the water in diesel filter warning light...Errr don't think that applies to my car lol
20-07-2013, 10:50 AM
I thought that, but then it's got marks where a bulb used to be there, which is odd
20-07-2013, 12:00 PM
Pop one in, see what happens? Lol
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
27-07-2013, 09:31 AM
(20-07-2013, 02:33 PM)Stephen Wrote: Yeah probably should of, it's all back together now though! ahhh this is the thread for me!! So I have constant light on now. its just failed its MOT, im not interested in the airbag working anyhow my 306 is also a 98 reg so in theory I don't need a light on full stop. can i just start hacking at the cables below my seat or do I need to go cutting elsewhere? thanks. Steve
27-07-2013, 11:05 AM
(27-07-2013, 09:31 AM)steveizz Wrote:(20-07-2013, 02:33 PM)Stephen Wrote: Yeah probably should of, it's all back together now though! I had this fella! Change the connectors for bullet or spade ones and it should be fine, failing that tap cully up for his mod - a pair of those should get the light out and problem solved
![]() the smokey old bus that sounds like a tractor...
29-07-2013, 08:11 AM
(27-07-2013, 11:05 AM)devils_fuel Wrote:(27-07-2013, 09:31 AM)steveizz Wrote:(20-07-2013, 02:33 PM)Stephen Wrote: Yeah probably should of, it's all back together now though! thanks will do, just so i am clear do i have to take the driving seat out and take swap the connector about under the seat or is there an easier way? just checked out the drivers seat and it seems a bit tricky to remove.
29-07-2013, 12:30 PM
Well you won't be able to do it with the seat in, so remove it and then it's easy access!
Black mask Service
29-07-2013, 07:24 PM
i changed the seats in my phase 2, for seats from a phase 3, they didnt have the connectors so my airbag light was on all the time. I took the bulb out for MOT and i got an advisory for it not coming on, but didnt fail
306
01-08-2013, 07:52 AM
Lol one of my mates had a problem with his airbag light on his astra it stayed on and was informed it would be a fail if it didnt turn off so he took off the clocks removed the bulb and connected a bulb to the (i) light cus that goes off after engine is started and passed its mot with that lol
(msg sent from hell)
01-08-2013, 11:22 AM
airbag . . .what airbag? . . . .
01-08-2013, 11:35 AM
Engine management lights are another issue mind.
Apparently it HAS to come on when ignition is turned too, and MUST turn off once the car is started. Basically its to catch people taking bulbs out...
22-08-2013, 04:27 PM
Niall, what resistors did you use to remove the seat airbags from the equation?
HDi Owner for 200k/9 years
22-08-2013, 04:32 PM
23-08-2013, 05:10 PM
(22-08-2013, 04:32 PM)cully Wrote: Money in the side eh cully
08-09-2013, 03:49 PM
Just order a few of those resistors, hopin they actually work.
12-09-2013, 10:38 PM
(08-09-2013, 04:07 PM)cully Wrote:(08-09-2013, 03:49 PM)KrisCampbell Wrote: Just order a few of those resistors, hopin they actually work. Selling many of these then cully ?? ![]() the smokey old bus that sounds like a tractor...
12-09-2013, 10:43 PM
(12-09-2013, 10:38 PM)devils_fuel Wrote:(08-09-2013, 04:07 PM)cully Wrote:(08-09-2013, 03:49 PM)KrisCampbell Wrote: Just order a few of those resistors, hopin they actually work. 1 or 2 but its been quiet this week
22-09-2013, 08:36 AM
Cully, is the one you've linked to for use anywhere on a HDi? As in pretensioner, or side airbag light, plug in under the seat, or at the ecu in front of the gearstick?
I need to frig my brothers light for MOT before Dec.
HDi Owner for 200k/9 years (22-09-2013, 08:36 AM)C2K Wrote: Cully, is the one you've linked to for use anywhere on a HDi? As in pretensioner, or side airbag light, plug in under the seat, or at the ecu in front of the gearstick? yes it will replace any of the bags or pretensioners it will only work only if you have a working system less bag or belt tensioner it wont magicly fix broken looms duff plug connections or duff airbag ECU's 1.8ohm i have found works on my Ph3 HDI and on a ph2
23-09-2013, 11:39 AM
Thanks, i'll order a set. Can't remember what PP was complaining about when i scanned his car at the time. I might PM you for advice next time I see him.
HDi Owner for 200k/9 years |
![[Image: 205sig.jpg]](http://i1016.photobucket.com/albums/af290/stephenraymond606/205sig.jpg)
![[Image: connorsig.jpg]](http://www.306oc.co.uk/forum/images/uploads/connorsig.jpg)
![[Image: siggy1.jpg]](http://i653.photobucket.com/albums/uu252/crissy_boy/Cars/siggy1.jpg)
306
![[Image: signature.png]](http://s22.postimg.org/cgh3ss11t/signature.png)
