Rev counter died
Rev counter died
This is an annoying problem, a year ago my rev counter went intermittent, then died completely. I have replace the sensor magnet with another one and now I have bought a replacement instrument cluster, still not working. The fuses are for the instrument panel as a whole so it can't be a fuse that has blown. Is there anywhere else that could stop the rev counter from working? Maybe the magnet has come off the flywheel perhaps?
Right, turns out the rev sensor needs to be pushed RIGHT in as far as it will go. Swapped the rev counter from the other set of gauges I bought so it turned out to be money well spent afterall Smile
(28-04-2013, 12:29 PM)306Puggy Wrote: Right, turns out the rev sensor needs to be pushed RIGHT in as far as it will go. Swapped the rev counter from the other set of gauges I bought so it turned out to be money well spent afterall Smile
What part needs to be pushed right in as my rev counter has also dies
NO SMOKE NO POKEBig Grin
  Alternator died Oldjon 1 2,454 15-10-2016, 04:49 PM
Last Post: reese
  Has my battery died on me! cpikey316_ 11 5,755 22-03-2014, 03:24 PM
Last Post: cpikey316_
  Headunit just died.. help Tom 15 7,890 29-02-2012, 10:44 PM
Last Post: stevieg
