Feel like having a rant for once
It's being a pain, as some might know from other thread(s) from me, I put on a 10mm pump I put together, to find out it doesn't work, so I took it off again, partially stripped it down, all looked fine. SO, I had the choice, try the 10mm again, or just save time and put the 9mm back on..I chose to try the 10mm.. Still no joy.
So today I took the 10mm off, put the 9mm back together and put it on, tried starting it, finally fired but very rough, presumed it was a tooth out, even though I never took tension off the belt, and cable tied the belt to the pulleys so the didn't move (obviously locked into place, not that daft) so I re-timed it, started, still very rough. So I timed it again, and it was still rough! By now i'm completely fed up of working on the bloody thing..Finally got it running, still pretty rough, so I gave the plugs a bit more heat whilst it running, didn't do much. I cracked off the injectors one at a time whilst running to get air out, and injector one wasn't spraying much at all, so tried to bleed them normally, still barely anything from injector one.
SO the car runs now, but is a complete pain to start, even priming the grenade it still takes a long while of cranking before it chugs into life. Thinking air is getting in somewhere? Maybe that's why I could bleed it properly?
That's one very long and boring rant, but I feel better for writing it! I hate my car sometimes!
If you have read it up to this point, care to shed any light on why it won't bleed, and why it takes soo long to start?
![[Image: connorsig.jpg]](http://www.306oc.co.uk/forum/images/uploads/connorsig.jpg)
![[Image: tapatalk_1427020983519_zpsnwvozlhb.jpeg]](http://i768.photobucket.com/albums/xx328/annegg5511/Mobile%20Uploads/tapatalk_1427020983519_zpsnwvozlhb.jpeg)
