09-02-2013, 05:50 PM
I keep seeing people using the non turbo cam in there xud. What's the benefits?has anyone else done it? Can't see the need for a cam in a derv myself
non turbo cam?
09-02-2013, 06:24 PM
(This post was last modified: 09-02-2013, 06:24 PM by 4WayDiablo.)
I don't think I've seen anyone do it tbh?
But as you say an improved can isn't really needed until you get to much higher power
09-02-2013, 06:36 PM
XUD9A Non Turbo Camshaft - 0801 E8
XUD9TE D8B Non EGR Camshaft - 0801 E8 XUD9TE DHY Camshaft - 0801 E8 Says about as much as you need to know I think?
09-02-2013, 06:39 PM
If you use a non turbo cambelt you also get more power
09-02-2013, 06:44 PM
Non turbo tensioners are a well known performance part also!
09-02-2013, 07:33 PM
Just pop a dab of weld on the tip of each lobe for a bit more lift. Works wonders
09-02-2013, 07:35 PM
(09-02-2013, 07:33 PM)Dan! Wrote: Just pop a dab of weld on the tip of each lobe for a bit more lift. Works wonders Sounds good to me lol ![]() Team derv FLAME and CONROD spitters
09-02-2013, 10:48 PM
So it's a load of rubbish then was a car on Ebay back along which said it had a non turbo cam for better lift. Dturbo owners group on Facebook also mentioned it yesterday.oh well cleared that up then shows the knowledge of this forum
Thanks
09-02-2013, 11:13 PM
try an electric supercharger...they are like a few quid on ebay...
give up to 50bhp increase!! Wishes for more power...
09-02-2013, 11:22 PM
Times are increased valve lifts to gain Hp.
Changing the size of the camshaft or if it is resized change the timing diagram. To gain more Hp, install a camshaft pulley adjustable or watch a bit of those some PSA Hdi settable origin. Changing the camshaft create a range of greater use at high speeds and is lose some low end torque. It may be possible that he's obliged to climb harder springs, or alleviation cups, valves and tappets to avoid panic valves. Changing valve springs, valve guides allows the bolt to be reliable ride high in the towers without breaking the head gasket, cylinder head or worse. Changing the valves of the power adapter can be useful. We talk about cams sharp, but it is the opposite, they are more rounded for easy valve lift. Piggy 1987 Useful post there well done
10-02-2013, 08:02 AM
its as useful as fitting a non-turbo cam...
dont use facebook as your guide...come here chap Wishes for more power...
Peace & L... Attitude 8-)
10-02-2013, 11:13 AM
10-02-2013, 11:16 AM
(10-02-2013, 11:13 AM)Frosty Wrote:(10-02-2013, 08:02 AM)Piggy1987 Wrote: its as useful as fitting a non-turbo cam... +1 Noone's tried to pass it off as true, the fella's come on here to clear it up, which it now has been. /closethread |
