Threads: 55
20-06-2012, 03:26 PM
(This post was last modified: 20-06-2012, 03:26 PM by Dicky.)
Is there an easy way of removing injectors from my car without an injector tool? From what I remember of doing my old engine I stuggled like f*ck to take them out..
Plus side injector seals were £6.40 for 4 from pug
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
Threads: 87
48
27mm draper deep socket is about 6 quid on ebay . . . .you'll want to use a breaker bar as well . .
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
(20-06-2012, 03:35 PM)Diggers Wrote: What engine? If its dturbo, 27mm deep socket from halfords then return it after
Sent from my HTC Wildfire using Tapatalk
halfords "DEEP" sockets are not deep enough FYI... the one i bought was as useful as a chocolate teapot
Draper deep sockets online suffice.
Phaes 1 GTI 6 - Onyx Black
Threads: 376
38
(20-06-2012, 03:46 PM)Diggers Wrote: (20-06-2012, 03:41 PM)ginge191 Wrote: (20-06-2012, 03:35 PM)Diggers Wrote: What engine? If its dturbo, 27mm deep socket from halfords then return it after
how deep you need it? :o
it worked for me, their diesel injector deep socket didnt fit thou
that one
Threads: 87
31
FYI Halfords 27mm normal deep socket works fine, plenty deep enough and never broken any leak off tabs.
Threads: 87
48
(20-06-2012, 03:46 PM)mark_airey Wrote: Or you could get a specific injector socket so you don't f*ck up the leak off connections on the injectors :rolleys:
Bunch of fooking pikeys I tell you!
you want this one - http://www.ebay.co.uk/itm/Draper-Expert-...052wt_1004
Also FYI halfords do also sell injector sockets
cheers Mark, that's what i meant, that's what i got and was fine . .
Threads: 15
Car Model/Spec: P2 Nile GTi6
The halfords one by me was useless aswell. Different ones must stock different injector sockets
