AC Delete
Hello all I am going to delete the AC when I change my Cambelt.
I have the manual tensioner and Belt I just need to get the idler wheel. Do I require any additional bolts?
I have read it it recommend to clear the threads with an M8 Tap does anyone have a guide for the swap?
Firstly, I know you already have a manual tensioner but I believe it is possible to remove the compressor but keep the existing automatic tensioner for the aux belt ....you just need a shorter aux belt. The vast majority of the weight savings are from removing the compressor anyway.
I tell you this because to fit the idler you need to put an M8 bolt in a threaded hole that has been exposed to road crud for the last 20 years (I.e. currently un used). If the engine is still in the car you can't get a tap on it.  The only option is to make your own tap from a short M8 bolt by cutting some slots perpendicular to the threads. It's a very fiddly job n even identifying the bolt hole in the first place is a bit of a pig ...just depends how patient you are!
Anyway, I did manage it but did think afterwards my time could have been better used on other things. I think I used a 20mm or 25mm bolt. Servicebox will tell you the correct size. You can't use the hex bolts from the aux tensioner because you can't get a hex spanner on to them as space is so tight.
Many thanks for the heads up would you know the size of belt required to just bypass the compressor?
I don't I'm afraid Dave but someone on here most likely will. TBH I can't think it will need to be much longer than the standard non-AC belt.
Sorry Dave, I might have dreamt up the thing about being able to keep the auto tensioner. Have just had a look back at these pics (downloaded from another site) n the auto tensioner would (I think) be sprung in the wrong direction!  Not sure if you'll come to the same conclusion?
Many thanks for the information
Just to update on this all parts fitted with no issues was a bit fiddly and tapping the unused holes was good fun.
Not that bad of a job though.
Well done mate. Like you say, all totally do-able. Just needs a bit of time & patience!
