  • 1 Vote(s) - 5 Average
Ecu and things needed to work
Hello I'm pulling parts of my 306 hdi.
The ecu I wanted to keep it has been remapped so what else is needed. I know the ecu and the key chip and the black barrel ring around were the key goes.
Thanks
Not the ring around the barrel.
The black box under the centre console, need to remove ash tray console and it has 3 torx screws under there.
(22-05-2016, 10:23 AM)Toms306 Wrote: Not the ring around the barrel.
Cool thanks I've just removed the ecu and kept the key and now will get that box in the centre console.
remember a 1 plug ecu won't fit a 3 plugged car or the other way round Wink
GTI6 Info
I got that black box out from by the ashtray. It had a blue and yellow connectors on it.
The screws were already of so somebody else must have been messing about there.
So that's the ecu, chip in key and black box.
Thanks
central locking circuit board in the keyfob too Wink
GTI6 Info
Yeah people seem to think the ring reads the code. But the fact it doesn't it only sends the signal.
The way it works the key chip responds to the black ring barrel which then sends signal to black box. The key chip code read in the black box and then sent to the ecu.
black ring is just a feneric aerial
(11-12-2016, 02:31 PM)welshpug Wrote: black ring is just a feneric aerial
Thanks for confirming this as I clearly know its not just me saying it.
  got some things that dont work bingham123456 8 5,203 13-12-2012, 01:25 AM
Last Post: Tom
