ECU repairers
ECU repairers
anyone recommend someone to repair a peugeot 2005 206 1.4 16V ecu?
i have one that reads no throttle sensor via planet although the sensor and cables meters out ok
GTI6 Info
These guys did an excellent job rebuilding the ABS pump on my brothers car, they do ECU work too.
http://www.ecutesting.com/
This place were on Wheeler Dealers I think.
http://www.bba-reman.com/uk/index.aspx
Pro Steve might be able to help!
/Toseland
(12-11-2015, 09:44 PM)toseland Wrote: Pro Steve might be able to help!
Think he only does diesels but I maybe wrong
I've used the ecu doctor, was pretty pleased with the service. We use cartech at work iirc, can check for you later.
Thanks given by: silverzx
camco in warrington near Liverpool
mobiletron advertising in a lot of trade magazines ??
(13-11-2015, 06:58 AM)Poodle Wrote: I've used the ecu doctor, was pretty pleased with the service. We use cartech at work iirc, can check for you later.
+1 for ECU Doctor.
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
