Threads: 124
26
Car Model/Spec: Megane DCiR
Hey guys,
Just wondering if anyone can help, ive recently been getting a screatch/ scream like sound mid range - mid boost,
Now my general thinking is if turbo was on way it would do it throughout boost.... right?
other possibilities im thinking could be slight boost leak maybe nicked pipe or cracked plastic boost pipe (off 406)
or maybe a pulley or something
any ideas
Threads: 96
Maywell just be fluid getting underneath the belt and making it slip a little
I've got a few of these noises on the hdi!
1. Slipping belt, despite being a new belt and tensioner
2. Clutch release bearing (more of a squeal)
3. Clutch plate slipping on boost
I'd go with a slippy belt for yours....seems common on 306s
Threads: 124
26
cheers tom i think you may be correct as last few days have started her up and its been squeeling like fook, only other thing could be power steering pump as its been ran dry for 6 months as hose was bolloxed and we changed it last month along with subframe and all new bushes and wishbones etc but had them go in past and the grind rather than screatch will check tension on belt today at some point
