In tank pump fuel strainer
My 306 hdi has started hunting now and then on idle. Its got a new air filter and cleaned the maf as well.
I changed the fuel filter before with the old one being a little black due for a change.
I just checked now and the fuel pump in the tank the strainer blocked up a lot. I can see a lot of black stuff built up on the white strainer.
So is there a guide pictures to removing the strainer out apart from the fuel pump plastic housing?
I dont want to break things if possible to do it right.
Thanks
http://306oc.co.uk/forum/showthread.php?tid=28530
[url=http://306oc.co.uk/forum/showthread.php?tid=28530][/url]In the guides section mate Tongue
(20-05-2015, 09:48 AM)JTaylor2005 Wrote: http://306oc.co.uk/forum/showthread.php?tid=28530
Nice one thanks
  Increasing fuel pump output? JTaylor2005 7 4,496 06-06-2016, 10:00 PM
Last Post: Ruan
  HP Fuel Pump FPR Bolts BiG K 13 6,765 30-05-2016, 06:30 PM
Last Post: pug306driver
  Removing Hp fuel pump Welshy_Pete 8 4,879 24-05-2016, 01:42 PM
Last Post: toseland
