19-12-2013, 06:11 PM
Can someone help me here;
It seems my fans are starting to have a mind of their own these days. Only recently, the fans kick into high speed for some unknown reason, which I believe is linked to the A/C.
Low speed fans should only kick in when the engine temperature reaches 97°C & it will turn off when the temperature has dropped to 90°C and when the air conditioning system is switched on. It will run permanently regardless of engine temperature. Car sits at just under 80, never gets hot.
High speed fans should only kick in when the engine temperature reaches 107°C, when the A/C refrigerant high pressure threshold is reached and when the temperature sensor circuit goes faulty. (open circuit)
What exactly does high pressure threshold mean on the A/C? Is this a fault or just a consequence of running the A/C for a duration?
