Threads: 80
Car Model/Spec: 1999 306 Meridian 1.9 TD
The bend in the centre section on my dt sits very low, probably no more than 4 inches off the ground, making it almost impossible to go over soeed bumps without scraping it, the car has been lowered 30mm on the front but nothing on the back, any one had the same problem and know the best way to fix it?
Cheers!
No smoke, No poke!
Threads: 151
14
Car Model/Spec: 306 D-turbo
Slacken of the clamp on the backbox/downpipe rotate the centre section so it's closer to the body and re clamp
Team Doesn't own a 306
Threads: 80
Ahh right just need rotating! Will give it a whirl when i get home
Cheers!
No smoke, No poke!
Threads: 151
14
That's all I have ever done when there sagging either that or new rubbers
Threads: 85
8
Car Model/Spec: E90 330i
I had a decat fitted last week and now the midbox hits the undersidewhen i turn left. Looked underneath and found the pipe sagging pretty low between mid and backbox, need to get it adjusted his week
Threads: 80
Was just a matter of rotating it haha sits nicely now so can actually go over speed bumps!
No smoke, No poke!
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
08-08-2014, 08:38 AM
(This post was last modified: 08-08-2014, 08:38 AM by silverzx.)
Heavy duty zip ties on the rubber mounts to lessen movement/vibration also help.
