No one will have the same key as you. Locking nuts would be pointless if that was the case!
Threads: 52
Car Model/Spec: 306 GTI-6
Kinda thought that, but guy at garage said I'd be able to. I tried to say otherwise but as a woman obviously I was talking rubbish
306
Threads: 465
114
Car Model/Spec: Vauxhall
04-12-2013, 06:25 PM
(This post was last modified: 04-12-2013, 06:26 PM by cully.)
mmm maltesers
side tracked
hammer a socket over the head then turn out as normal
or
buy some locking nut removers
Threads: 52
04-12-2013, 06:42 PM
(This post was last modified: 04-12-2013, 06:42 PM by Nadine.)
Lol wondered what the maltesers was about. Got a mate gonna try it 2moro
306
Threads: 62
10
Logically, it would be a logistical impossibility to stock an infinite amount of types of locking wheelnut. You'll find there will be circa 20 types of them on 306's, so the statistical chance of finding someone with the same key (only the key is numbered normally) is slim.
I had to take the same type off once on a breaker when the key snapped its pins. Tighten the other three bolts up a bit to relieve the tension slightly on the locker. Smash an 18mm 12 sided socket on and use a breaker bar to crack it off.
HDi Owner for 200k/9 years
Threads: 164
25
Car Model/Spec: Gti6
Weld a nut to it and undo it that way ?
