Here is my passenger footwell with the carpet pulled back, at the inside of the bulkhead.
[attachment=11242]
(The visible leak is more easily identifiable if you zoom-in on the photo.)
As you can see, there is a small leak coming from the inside of that large rubber grommet. Is that the air-con grommet?
Surprisingly, I can confirm that there is no leak whatsoever coming from the hole surrounding that red 4awg amp power cable running to the boot. That entire area, including deep inside the hole, is completely dry.
So the leak is coming solely from the large rubber grommet itself. Unfortunately, it is frequently making my passenger carpet very wet.
So what is the nature of this leak, has anyone seen it before, and is it something which I can repair myself?
[attachment=11242]
