Threads: 190
Car Model/Spec: HDI
you need stretch running that offset though
Threads: 46
21-03-2013, 11:32 PM
(This post was last modified: 21-03-2013, 11:32 PM by Pete.)
Daves 306, Pretty sure theyre 185/45 on an 8x15 rim..Looks bang on and no kittens or nuns have died as a result
Got 195/50's on 8.5x15 rims on the van and they look like balloons in comparison!
Threads: 190
Car Model/Spec: HDI
Cheers mate, nankangs are the only 185's I can get, whereas 195 offers more range
Threads: 79
17
22-03-2013, 01:07 AM
(This post was last modified: 22-03-2013, 01:08 AM by Slam Wagon.)
Ive got 8j -20 et with 185/45 on the rear 195/45 on the front. Will grab some pics tomorrow. 185 looks good if you want stretch but i dont want to have to run cheap narrow tyres where i dont have to so ive still got my 195s up front.
Threads: 190
Car Model/Spec: HDI
really mate? see it all depends what brand of tyres i suppose as to how they stretch?
Threads: 208
60
Given 5 thank(s) in 5 post(s)
id personaly go for a minimum of 195.
A. because 185 just dont have enough contact area with the road
B. becuse nagkangs are like plastic and dont grip. it will wreck the drivablitybof the car
Threads: 190
Car Model/Spec: HDI
what is a good brand of 195s then mate? I don't really know much about rubber lol
Threads: 208
60
22-03-2013, 10:59 AM
(This post was last modified: 22-03-2013, 11:06 AM by puglove.)
depends what you want to spend. im guessing yoy want somthing mid range. and value for money. yokaharma spec2s or toyo proxy's 195/50/15 will give you a really good amount of grip for the money you are spending
(toyo T1R's)
EBAY : spec2's £192 for 4
toyo T1R's £165 for 4
i personaly run T1R's on my 6 and they are epic compared to what eles you can buy in the price range. side walls are abit softer than id like but with you running strech this shouldnt be an issue
Threads: 190
Car Model/Spec: HDI
What confuses me is that daves 195's look pretty stretched, whereas pe02's fronts don't look that stretched
Threads: 190
Car Model/Spec: HDI
That's a good comparison cheers. I think there is quite the difference. But will I get 195's below the rear arches at et -12
Threads: 190
Car Model/Spec: HDI
Daves are et -8 and didnt need too much, you are et -20 and needed a lot....and I'm somewhere in between hahaa
Threads: 79
17
Depends on 3 door or 5 door an ride height too
Threads: 190
Car Model/Spec: HDI
Well thats it mine is only 60mm atm and only wanna go slightly lower tbh
