Threads: 198
135
Can't you just cut the connector off the standard pipe and slide it over the R70 union?
Threads: 202
58
it's plastic pipe, i think it'd just split..
Threads: 198
135
I think you should try it first seen as that connector ain't fitting...
heat ftw
Threads: 130
82
Car Model/Spec: 106 GO-NAD
The fuel lines on our cars are pretty goddamn strong, even after soaking it in boiling water I still struggled to get a connector on. Hammer FTW I say
26-10-2012, 03:50 AM
(This post was last modified: 26-10-2012, 03:51 AM by Poodle.)
The fuel hose i have on there was rubber in the first place...
That's your third piston shut-off return to the tank so it shouldn't be under any real pressure if you unplug the solenoid, if you can get the plastic fuel pipe over the fitting it should hold until you get to a parts place.
Threads: 90
Just use rubber fuel hoses / do away with that hard plastic crap...you wont get the plastic stuff to clamp down / seal very well, its not meant for that as its heat shrunk at the factory...
