Useful part numbers
Useful part numbers
Ive gotten together a list of the common parts that people buy from pug. Will be adding to these as and when I get time.
Note: please check parts such as engine parts against your VIN when ordering. I've put down the latest part numbers available but some parts could be different on your car age dependant. I'm not responsible if you order the wrong parts!
Note 2: prices are all current Peugeot factory prices. Prices vary over time and between dealers and so should be taken as a guide price. Dealer prices are always very close to these prices if not sometimes cheaper.
Useful Part Numbers
Body parts and fixings
Hockey stick left ph3 - 7810 A6 - £9.85
Hockey stick right ph3 - 7810 A7 - £9.77
Hockey stick clips - 7813 26 - £0.60 each
Grill pop rivets - 7813 24 - £0.36 each
GTi6 splitter - 7414 L0 - £55.01 kit
Rallye blanks - 7414 L2 - £14.93 both
Door rubbing strip clips - 8565 40 - £0.20 each
Interior parts
Tweeter cover left - 9015 P4 - £1.80
Tweeter cover right - 9015 P5 - £1.80
Trim clips - 6966 39 - £0.84 each
Engine parts - petrol
Oil filter - 1109 T0 - £10.80
GTi6 inlet gasket - 0349 G1 - £3.38
GTi6 throttle body gasket - 1635 C3 - £0.64
GTi6 engine gasket set - 0197 W2 - £108.71
XU exhaust gasket - 0349 F4 - £22.72
Exhaust fitting kit - 1798 75 - £21.56
Other parts
GTi6 engine - 0139 Y6 - £3523.09
Bare 3door body without sunroof - 7050 L6 - £2730.96
307 Mist washer jets - 6438 H4
Hockey sticks are different from ph1->ph2/3 so you might wanna add that the list
Cheers Connor :clap:
£3523 for a gti6 engine! f*cking lol
Matt Wrote:£3523 for a gti6 engine! fornicating lol
There is also a 530 quid surcharge to add to that
I've got another parts list, which I'll add these to, then post the spreadsheet as an attachment Smile
307 mist Jets (same as xsara) 6438 H4
No those are the wrong ones dum, the ones you want end in v8, not h4
  306 rallye engine part numbers needed.. Matt-Rallye 3 3,172 14-05-2014, 10:13 PM
Last Post: miles
