03-04-2018, 04:22 PM
Hi all, I'm new to the forum. Recently purchased a 6. Any recommendations on what air filter set up is best on these?
cheers!
cheers!
air filter 306 gti6
cheers!
03-04-2018, 08:12 PM
The stock air filter is pretty good. Id suggest just cleaning up the oem air box. You can fit a cone filter but youll get heatsoak in the bay and it may get wet if you mount it low down!
Having done most things I would suggest the money would be better spent on making sure the brakes and suspension are set up. If you want to do anything to the engine/box a lightened fly wheel probably gives the most noticeable improvement. Fit it when you need a new clutch to save £££. Thanks given by: nile306gti6
04-04-2018, 08:59 AM
+1 on the stock air box tbh, they're getting harder to find too - be worth tidying it up before it turns to dust like most of the others!
| Inlet extension for air filter; GTi6 - what do you use? | ginge191 | 15 | 7,705 |
08-07-2013, 02:35 PM Last Post: Puggie |
