Auxiliary belts
Auxiliary belts
Huh hi. All. Does anyone have a auxiliary belt diagram for a 1999 306 1.4 with a/c,  p/s and alt?
Bel flew off o motorway.
Motorfactors are confusing me as some say there is one belt others say there are two.
As no belts visible i really need help. Thanks
Looks like a twin belt. Buy both options and send back what you don't use.
Thank you so much. I need as much info as its my first cam/auxiliary belts change. Fingers crossed.
Sent from my SM-G900F using Tapatalk
Problem two...
How do i release the tension on the auxiliary belts? It already doing my head in.
There are a few different tensioners, I think with yours you loosen a bolt then use a 1/2 bar in the square hole to move it round.
That will work on the cambelt but there is only one tensioner on the p/s , a/c belt with a torque screw in center but there is no tensioner on the gen belt?
check to see of the alternator swing in and out
