Servo push rod adjustment.
After fannying around with master cylinders I've now got the car bled and a good non sinking pedal, albeit little longer than I would like.
How do you adjust the rod inside the servo? It's not obvious like others I've seen, ATE system. Will attach photo of what it looks like!
100% no air, pressure bled and non sinking,
Thanks, Ali
[Image: F2DCF09E-59F6-4E35-B52C-BEBF36A70A1D_zpsiwjrumpw.jpg]
some are not adjustable like the older ones.
Ahhhh, don't say that!
  Fitting A New Break Servo TommiePuglet 19 13,682 05-10-2017, 12:19 PM
Last Post: TommiePuglet
  Brake booster servo Welshy_Pete 0 2,029 04-07-2017, 09:09 PM
Last Post: Welshy_Pete
  406 servo relocation? Daniel306 3 3,679 27-02-2014, 12:42 PM
Last Post: Daniel306
