GTb2056VLK
For Sale: GTb2056VLK
Garrett GTB2056VLK
Originally from a XC90 D5 Volvo.
Has been run on my 2.1 for about 4k miles and made well over 200bhp on a basic tune on a RR.
Stonking turbo for a great price. Flanges are easy to make and gaskets available on ebay for a decent price
Good condition.
£150 posted
£140 collect at FCS
[attachment=23546]
[attachment=23547]
any interest?
Too complex I'm guessing for most of us.
93 106 xsi
98 306 1.9d
98 306 1.9td lx
01 306 2.0hdi
97 306 1.9td estate
96 306 dturbo
96 306 dturbo
Id have this in a heartbeat just no monies for months now Sad really hope it goes to someone that does it justice
Can you post more pics?? Is it vacuum controlled?? I need more pics to see if I can fit this on my 306 with the 16v head
(04-06-2015, 10:22 PM)dashmader Wrote: Can you post more pics?? Is it vacuum controlled?? I need more pics to see if I can fit this on my 306 with the 16v head
it's controlled however you decide to Smile
What pics do you need and I will take them for you Smile
I need to see the oil intake in relation to the exaust intake. Also the vnt rod in relation to the oil and exaust intake. This is to see if I can put the turbo on the back of the engine,like the orginal one is put
You can clock it all 360degrees bud
So how would I go about fitting this turbo to my xud which is pretty much standard at the minute?
(06-06-2015, 01:00 AM)Spoonaltap Wrote: So how would I go about fitting this turbo to my xud which is pretty much standard at the minute?
welder
bolts.
research.
bump Smile
(05-06-2015, 04:24 PM)dashmader Wrote: I need to see the oil intake in relation to the exaust intake. Also the vnt rod in relation  to the oil and exaust intake.  This is to see if I can put the turbo on the back of the engine,like the orginal one is put
both hot and cold sides will rotate 360degrees so I am quite sure she would squeeze down the back Smile
Can you give a price on postage to azores/Portugal
(15-06-2015, 07:17 AM)dashmader Wrote: Can you give a price on postage to azores/Portugal
yeah sure I will find one later Smile
Ok thanks. I will try this one. This is controlled by vacuum right
(15-06-2015, 07:24 AM)dashmader Wrote: Ok thanks. I will try this one. This is controlled by vacuum right
or boost can or electronic, whichever you choose to use.
I fitted a vac can and am using arduino
Ok. On my 306 I am using ecu controlled vacuum. So vaccum is the right way to go for me. But boost isn't bad too
weekend bumpoid Smile
  FOR SALE: GTB2056vlk Piggy 19 5,324 27-10-2014, 03:53 PM
Last Post: Piggy
