Threads: 8
Car Model/Spec: Citroen zx volcane td
04-02-2015, 11:04 AM
(This post was last modified: 04-02-2015, 11:05 AM by dt_.)
I've had a zx for a while now and am really getting on with it, I know there's a couple of other guys on here with zxs but with this place being a 306 owners club the majority of you are running them.
Styling aside, what are the pros and cons of each when compared against each other? Ill try and kick this off
306 has wider front track
Zx is ~ 100kg lighter than equivalent model
306 specific parts much more readily available
306 slightly better interior space
306 seems to have a proper expansion tank
Any more to add?
Not sure what's going on with that font!
Threads: 14
7
Given 5 thank(s) in 5 post(s)
ZX D-turbo's usually came with the Bosch pump, whereas the 306 more often came with the Lucas.
Threads: 42
28
track width doesn't make any noticeable difference, its only the front anyway.
not needed any zx specific parts other than some body trim.
interior in the ZX no smaller, boot infact is better shape and rear visibility is better too!
depends which model you have, and not sure what you mean but they all have some kind of expansion tank, I hate those separate types on the later diesel 306's.
ZXs go on sills, 306s go on rear arches, both go under the front arch when the underseal cracks, wouldn't say one is worse than the other.
The radiator tank is not connected how you think, it is still a proper coolant tank really, it just so happens to be attached to the side of the radiator.
Threads: 371
29
Car Model/Spec: ford fiesta
Plus phase ones have the same rad a zxs.
Threads: 46
6
Car Model/Spec: Renault Scenic 2.0
Given 6 thank(s) in 6 post(s)
both my zx's went through underneath the PAS reservoir, i lost about 25x10cm before it properly showed through
Project: Formula Peugeot
Threads: 42
28
my first one was solid, shame I bent it, second one needed rear jacking points doing.
